Basic Settings
| Setting | Default | Description | ||||||||
| Height | 160 | Enter a height (in pixel) of masthead | ||||||||
| Title | Optional text for the text title element. If blank, a default value is used based on the page title | |||||||||
| Description type | Custom Text | Select option to use as description
| Custom Description | Enter a description | |||||||||
| Description text limit | 100 | Maximum length of description text | ||||||||
| Text Color | #FFFFFF | Specifies the text color to be used | ||||||||
| Text Shadow Color | Specifies the text shadow color to be used | |||||||||
| Text Alignment | Center | Select a text alignment
| Background type | Solid Color | Select a background type
Solid Background Settings
Background Settings
| Solid Color | #2886E8 | Specifies the background color to be used |
Gradient Background Settings
Background Settings
| Setting | Default | Description | ||||||||||||||||||
| Gradient Style | Linear | Select a gradient style
| Gradient Direction | to Bottom | Select a gradient direction
| Gradient Direction | Middle center | Select a gradient direction
| Gradient Size | Farthest Corner | Select a gradient size
| Start Color | #82b7ed | Select a gradient start color | ||||||||||||||||||
| End Color | #2886E8 | Select a gradient end color |
Image Background Settings
Background Settings
| Background Image | Select a background image |
Video Background Settings
Background Settings
| Video Poster | Specifies an image to be shown while the video is downloading, or in case browser does not support to play video. | |||||
| Video URL | Path or URL to video source. Supports video format mp4, WebM, Ogg | |||||
| Loop | Yes | If yes, the video will start over again, every time it is finished
| Muted | Yes | If yes, the audio output of the video will be muted
Mask Settings
Mask Settings
| Mask Image | -1 | Select a mask image | ||||||||||||||||||
| Mask Color | Select a color of mask. If Mask Image is selected, Mask color will have no effect. | |||||||||||||||||||
| Mask Opacity | 0.5 | Select mask opacity. A lower value makes the element more transparent.
